N3 Touchscreen Calibration
By coop · Oct 19, 2007in Problems/Troubleshooting💬 9 posts👁️ 2,284 views
Posted Oct 19, 2007 · 10:56 UTC#1
My touchscreen is off by about a half inch on the left side, which is where the slide bar is. How can I re calibrate the screen without taking it in for warranty?
Posted Oct 19, 2007 · 17:23 UTC#2
I believe someone on here posted how to get into the hidden service menu and was able to do it through there
Posted Oct 20, 2007 · 03:13 UTC#3
I found one on the n2 but not the n3
Posted Oct 20, 2007 · 03:35 UTC#4
Probably the same
Posted Oct 20, 2007 · 17:48 UTC#5
It was actually fir the n1 and it did not work.
Anyone know how to get into the service menu on the n3?
Posted Dec 22, 2007 · 21:21 UTC#6
Same problem here. Drives me nuts. I got an avic-n1
Posted Aug 21, 2008 · 19:15 UTC#7
Remove any disk's from the headunit.
Hold reset and eject together, then release the reset button but continue to hold eject.
The screen will go in and the come back out. The screen will now say to press the reset button - DONT FOLLOW THIS PROMPT.
Then with joystick, (knob on the rigt side) follow this, by moving the joystick in the directions below:
Up, Right, Up, Right, Down, Right, Down, Righ and then finally press the joystick inwards, in the center. Now, the password screen will come on for a few seconds followed by the test mode.
When you are on the first page in the secret menu, you are presented with the option of Remocon touch panel test. You then need to find the setup calibration option. Once you enter the calibration section, you should see a cross on the screen. Use a stylus or similiar and touch the center of the cross as accurately as possible, you will find another cross will appear, do the same to this and all the other crosses that appear. Eventually, the monitor will tell you that you have completed the calibration.
If you messsomething else, use the BAND button (on the top of the screen's edge when it is out) as the BACK button.
Posted Aug 31, 2008 · 10:03 UTC#8
Ever get it fixed Coop?
Posted Sep 01, 2008 · 21:31 UTC#9
yea, i just took it out and back to best buy. they covered it under the extended warranty. i just didnt want to wait 3-4 weeks without a radio, but it works great now.
thanks for the service menu how to.....i will keep that in mind if it ever happens again.
