Hi I have been told to connect the VSS wire to the White/Orange wire in the center console on a 40 pin connector but can't find the correct wire anyone else have this problem even had a tech try to find it and he couldn't, he hooked it to the output on the trans and that showed the vehicle as going down the road even if you were sitting at a traffic light with the brake on, is the 40 pin connector the factory radio harness plug ? Jeff
Posted Oct 21, 2007 · 16:40 UTC#1
