Whirring/Grinding? Noise - Z1
By jdbara · Oct 22, 2007in Problems/Troubleshooting💬 3 posts👁️ 681 views
Posted Oct 22, 2007 · 19:56 UTC#1
I've had the Z1 a little less than a year. Lately, I've been getting a noise from the speakers that only occurs when I start the car or turn the car off. The best I can describe is a whirring or grinding sound. It stops once the unit boots up or the car is shut off. It does not matter if the car is running or not - just powering up and powering down. I have not done any of the mods nor installed any of the updates. Has anyone else experience this? Thanks for your help.
Posted Oct 22, 2007 · 22:06 UTC#2
Does it make this noise on any source or is it confined to one (fm tuner, for example). If it is everything, could be the internal amp (send to pioneer for service) if it is one thing (Ipod or XM) that is connected to IP bus, could be a bad cable or a bad componant.
My best advice would be to let a GOOD local installer have a look. Sounds like from your discription to be equipment related and not install related. Just may need some real troubleshooting to pinpoint. Since you didn't say what kind of car, or any ad-ons you may have, I can only guess.
Posted Oct 23, 2007 · 17:28 UTC#3
That's a good idea - it might just be the Ipod, I hadn't considered that. I'll give it a shot - Thanks. (2006 Mustang with the rest of the Shaker 1000 system intacts - only replaced the head unit).
