Which Wiring Harness?
By 2004.5 3500 · Oct 23, 2007in General💬 4 posts👁️ 932 views
Posted Oct 23, 2007 · 19:18 UTC#1
I'm getting a D-3 and installing it in 04 Ram 3500. I know I have to mod the bezel first. Truck has Infinity w/Nav that is OEM. Which harness should I use? Keep the Infinity amp or bypass it ?? Thanks for any help.
Posted Oct 24, 2007 · 14:13 UTC#2
I used www.metraonline.com to find my parts. Crutchfield is pretty good about helping with that stuff but they didn't help me much when I called about my current install. Metraonline's website you can set your vehicle and find what you need from there.
You'll need a Metra 40-CR10 or 40CR-30 for the antenna.
I see only a 70-6510 harness that bypasses the Infinity Amp I'd get with a professional installer for more advice this is trickier to get information than my truck was.
There is another 71-6502-1 Harness but I don't know what it does.
Posted Oct 25, 2007 · 03:57 UTC#3
Thanks for the info.
Posted Oct 28, 2007 · 04:05 UTC#4
71-6502 is the reverse harness, not needed.
