AVIC D3 and CD BTB200 bypass problems
By tdrake · Oct 23, 2007in Problems/Troubleshooting💬 4 posts👁️ 961 views
Posted Oct 23, 2007 · 19:23 UTC#1
I recently did the bypass on a 2000 civic and was working perfectly for about a week till I got the CD BTB200 installed and now I get warnings that the parking brake wire is not installed correctly. So I went back in and checked all my connections and they are tight. All I can think of is that I grounded the bluetooth unit to the same wire that I did the bypass on. Can anyone help point me in the right direction?
It works but only under 15mph
Posted Oct 23, 2007 · 20:35 UTC#2
The bypass is most likely done incorrectly. Recheck the wires for the bypass. It sounds like that when you installed the BT unit around the same time your D3 fully calibrated and locked you out. That is a symptom of an incorrect bypass.
Posted Oct 23, 2007 · 20:38 UTC#3
i did exactly the way it said to. And the d3 has been hooked up for a week or more. Parking brake wire wired into the ground along with the mute wire moved and grounded. Could my problem be that I grounded the BT unit in with the other grounds.
Posted Oct 23, 2007 · 22:29 UTC#4
You probably knocked one of them loose while messing with the wiring back there
