upgraded DVD now dead
By Smaay · Oct 24, 2007in Problems/Troubleshooting💬 10 posts👁️ 1,411 views
Posted Oct 24, 2007 · 13:53 UTC#1
i have a AVIC90DVD on a 6400 screen. about 3 weeks ago the navigation stopped working. i could see real time but no longer add new destinations, and if i picked POI the screen would go blank then turn white. so i was hoping the DVD was bad. well i bought a newer DVD on Ebay. not a copy but original. Loaded it and it appeared to update the system. after 2 status bars finished, the system reset. now its saying i have in invalid dish, please replace with correct disk. and my old disk does the same thing. worse than that, the radio and CD and DVD features are all locked out too..
HELP!!!!
Posted Oct 24, 2007 · 17:32 UTC#2
Which disk?
Posted Oct 24, 2007 · 20:33 UTC#3
40MT i believe, i think i figured it out. the system is looking for a touchscreen and my 6400 is not. im going to try to downgrade the system.
Posted Oct 24, 2007 · 22:33 UTC#4
Ya, if you can find a 40R it should work
Posted Oct 25, 2007 · 22:51 UTC#5
well the downgrade steps worked, im back to square 1.
so why can i not enter new destination? its grayed out. all i can do is map search
Posted Oct 26, 2007 · 13:45 UTC#6
HELP folks...is the DVD bad or my system?
Posted Oct 29, 2007 · 03:01 UTC#7
sounds like your oparking brake cable wire (which you should have grounded) has failed if you say the functions are greyed out make sure your ground wire is ok
Posted Oct 29, 2007 · 21:58 UTC#8
well the wire was grounded, but its possible that it came ungrounded. but would that cause the screen to go white when i do a POI search?
Posted Oct 30, 2007 · 05:55 UTC#9
No
Posted Oct 30, 2007 · 20:59 UTC#10
so could there be something mechanically wrong with my system?
