Ipod Interface
By jlolli · Oct 24, 2007in General💬 8 posts👁️ 1,396 views
Posted Oct 24, 2007 · 17:05 UTC#1
I did a search on this but didn't generate an solid advice... Is it possible to speed up or change the ipod interface??? I have an 80gb Ipod thats full for the most part and navigating through the 100s of artist takes forever. Any help is appreciated.
Thanks in advance.
Posted Oct 24, 2007 · 17:29 UTC#2
No
Posted Oct 24, 2007 · 19:09 UTC#3
Aside from deleting stuff, no.
Posted Oct 30, 2007 · 20:55 UTC#4
Divide your artists up into genres and then first search by genre. You should be able to reduce your list sizes that way (Classical, Country, Rock, Pop, Rap etc.). Even if you listen to, say, mostly heavy metal music you could divide into Thrash Metal, Speed Metal, Classic Metal, Pop Metal, Hair Metal etc. If you listen mostly to classical you can create genres for Romantic, Classical, Baroque, Modern etc.
Posted Oct 31, 2007 · 16:05 UTC#5
What the hell is the Menu Button in the wheel?
Posted Oct 31, 2007 · 16:58 UTC#6
UP?
Posted Oct 31, 2007 · 17:22 UTC#7
Same thing as the menu button on the ipod!!
Posted Oct 31, 2007 · 21:29 UTC#8
I did something very similar. For the GENRES category (Which i almost never use), I put the Letters there A, B, C, D, ... , Z, #
Therefore, under A you have your Artists that begin with A, etc...
Therefore, I can look for Albums AND Artists by letter. :)
Thats how mine is set up and I've been using it for a while. It's definitely the easiest way I've found so far.
