Avic D3 Wiring for 05 Chevrolet Trailblazer
By StormPursuit · Oct 27, 2007in General💬 25 posts👁️ 4,781 views
Posted Oct 27, 2007 · 00:02 UTC#1
I have a 2005 Chevrolet Trailblazer with Onstar, etc. I don't believe I have bose. The 6 disc changer that came stock with the vehicle was bose; however, I know there is not an external amplifier,etc. I also have controls on the steering wheel. What harness do I need to keep all of my factory controls and abilities and associate them with the D3? Also, where can I purchase this harness? I'll take pictures and post them as soon as the install is complete. Thanks for any help you can provide!!
Posted Oct 27, 2007 · 22:06 UTC#2
..................... any help would be great.
Posted Oct 28, 2007 · 04:00 UTC#3
You need to find out for sure if it has an amp. Trailblazer XL is on the left rear side, normal trailblazer it's on the right rear, behind the panels. You could write down the vin nmber and call the dealer, they should be able to tell you if you can convince them to look. The factory amp is digital turn-on, so definetly need a module/harness.
Metra gmos-01 for non amplified, gmos-04 for amplified. Steering wheel controls would be Peripheal peswips.
Posted Oct 29, 2007 · 23:56 UTC#4
You will need a Peripheral electronics GMAH24 interface, a GMAHCM chime retention module, a Metra 40-GM10 antenna adapter, and a PE-SWIPS steering wheel interface. If you DO have a Bose system, use the GMAH24B instead, and you won't need the GMAHCM. Your statement that the factory 6-disc changer was Bose leads me to believe you do have a Bose system. Was that an in-dash changer?
Posted Oct 30, 2007 · 02:30 UTC#6
all those products work fine my shop uses metra and ai and pac. pac swi-ps for sw controls, gmos04, gm06, gmk422. you can use another pacswips if you have rear controls.
Posted Oct 30, 2007 · 21:43 UTC#7
Yes, it was a factory 6disc in dash changer; however, I tried to install a factory Navigation unit from GM that was meant for my year vehicle but the dealership said since I dont have a bose amplifier installed that I am unable to install the navigation unit. So, I bought this Avic system. I am thinking that the Bose was built into the 6 disc changer and that the vehicle doesn't have an "external" amplifier somewhere else in the vehicle. Thats why I'm trying to find out what all parts, modules, harnesses, adapters, etc I will need before I install it this weekend.
Posted Oct 30, 2007 · 21:49 UTC#8
In that truck, the head unit did drive the speakers directly. The factory nav unit relies on an external digital amplifier to drive the speakers. Also, the factory nav units are VIN locked to the vehicle they came from, so, to bypass the security feature, you need a buddy at the dealer.
Posted Oct 30, 2007 · 22:18 UTC#9
If you had the 6 disc in dash changer, you have a factory bose amp. best way to know is to listen to the dash speakers. If you hear something there, you have bose. Nothing then no. Make sure to use the correct interface to retain on-star.
Also VSS is green/white in the 4th pin in on the guage cluster plug.
Illumination is brown in the main harness under the steering wheel, test this as there are several brown wires. You want the one that goes to 12v when the parking lights are on, and 0v off. 8)
Posted Oct 31, 2007 · 02:23 UTC#10
Oops, just noticed the 6 disc changer answer...
Posted Oct 31, 2007 · 03:58 UTC#11
Thats interesting.. I had a buddy at the dealership clear the theftlock and marry the factory navigation unit to my vehicle. It worked perfectly, just no audio out of the speakers.. .. Audio came out of the speakers, but so quiet you couldn't hear it at all, nothing was driving the audio. Dealership told me that the reason it was doing that was because the navigation unit was bose, and I didn't have a bose amp. That is why I'm curious, and want to make sure I get the right equipment to run my new Avic D3.
Posted Oct 31, 2007 · 17:52 UTC#12
I tried using the factory nav from an H2 in a Silverado with the same basic system, no worky....
Posted Oct 31, 2007 · 18:03 UTC#13
There are basically two bose systems for GM out there. One is basic, for Silverado, Tahoe, Trailblaizer, etc. and then there is premium bose for H2, Escalade, Denali, more upscale vehicles. With standard bose, if you remove the factory radio, you will lose chime and the radio sends 4ch of audio information to the amp. It crosses over everything, amplifies it, and powers the speakers. Premium bose on the other hand sends a digital signal from the head to the amp, and the amp takes care of volume, fade, chime, eq, everything. You cannot interchange the radios. Most vehicles that came with factory nav also had premium bose. The only one I can remember that did not was the Suburban LTZ with nav and RSE.
At any rate, I think the trailblaizer was only available with the standard bose system, and if you have the 6 CD changer, you should have bose.
Posted Oct 31, 2007 · 18:17 UTC#14
Ok, since we've came to the conclusion that my vehicle is the trailblazer lt, standard audio then that means I need a Peripheral electronics GMAH24B interface, a GMAHCM chime retention module, a Metra 40-GM10 antenna adapter, and a PE-SWIPS steering wheel interface. After I get those, my system will be ready for install?
Posted Oct 31, 2007 · 20:23 UTC#15
Yes. 8)
Posted Nov 01, 2007 · 03:21 UTC#16
Looking up that part, it looks as though it is for vehicles with Bose.
I still reccomend the GMOS-01 non Bose interface. Newer models of that unit also include VSS, Reverse and parking brake wires right on the harness. No seperate chime module needed either.
Just to be clear, this would be for non-amplified vehicles.
http://documents.victorytechnologies.com//documents/product/GMOS-01.pdf
Posted Nov 01, 2007 · 06:37 UTC#17
Dash kit - Best Kits or American International GMK422 and if your original head unit was a Bose unit, use the Bose interface...check here... http://peripheralelectronics.com/techPD ... A-Head.pdf
Posted Nov 01, 2007 · 14:06 UTC#18
Superjet, thanks for the reply, but I think you might be confused. He HAS a bose system (at least I think so) and would need a bose retention module. I work on at least 4 GM SUV's a week, so I think I know what I am talking about.
Posted Nov 01, 2007 · 15:54 UTC#19
As he stated a few times, he does not have Bose. Regardless, Metra still is a better choice, since newer versions have the Nav wires comming out of it. No need to go searching for VSS, parking brake and reverse.
GMOS-01 non Bose, GMOS-04 with Bose. Again, just call the dealer with the VIN number and find out, or pull the back panels and see if there is an amplifier.
And I don't even want to go there with how many installs I or you have done, as I can pretty much gaurantee I have you beat.
Posted Nov 01, 2007 · 15:57 UTC#20
ok i had a factory radio in my 2004 yukon that was a 6 disc head unit, i`m thinking of installling a plug and play delphi tnr nav factory nav unit in my truck , where can i get the wire harnes from and what else do i need?
my front speakers have bose on the door.\
i have the d 3 insalled now
Posted Nov 01, 2007 · 22:31 UTC#21
If you can beat 20 years experiance in this biz, my hat is off to you. If you would have read the entire thread, though, he said he had an in dash 6 cd changer that said "bose" on it when he started the truck.
I will agree metra's versions save time, but not all dealers use metra. My shop uses metra and peripheral, and I prefer the peripheral stuff for on-star retention.
Posted Nov 02, 2007 · 01:03 UTC#22
Wow, Marc, I didn't think there were too many others that have been in the biz as long as I have, I hit 20 years last July...
Posted Nov 02, 2007 · 14:41 UTC#23
Well, Jimmy, welcome to the "Old Guard" as I like to call it. Times, cars, and this industry have all changed.
Posted Nov 02, 2007 · 17:08 UTC#24
No kidding...
Posted Nov 03, 2007 · 00:47 UTC#25
I'm right there with you guys.
