I did the 2 wires bypassed and the updated software, Navigation functions work great but dvd movies can't be watched? Can somebody help me? I'll be happy to donate....
How to watch movies while dirving?
you probably didn't do the 2 wire bypass right.. i would make sure you grounded the right wires.. and that your grounds are good.
I checked the wires and I did exactly how the instruction is. I was able to use all the navigation functions while the car in motion, but not able to watch movie when the car go faster than 15 mph. Another question is why can't I use the wheel steering remote control when I bypassed the second wires. (the yellow MUTE wire) Any idea Why ?
I would like to say thank you for your time and consideration
Based on what you just said it indicates the bypass is done incorrectly or a wire has become dissconected. You will be able to use your nav fictions while your unit is calibrating but as soon as it is done you will be locked out of your nav functions as well. Recheck your wires and make sure one of them hasn't become disslodged from the harness.
I really got it to work. I did check the 2 wires and and they were not complete connected. Everything works great.
You guys are the bomb............ Thanks
I also did the 2 wire bypass and everything work great, THANKS.
I haven't been able to play VCD or SVCD in the AVZ-2.
Is it even possible???
I also did the 2 wire bypass and everything work great, THANKS.I haven't been able to play VCD or SVCD in the AVZ-2.
Nope
