I cant access the oem setting after trying to debug mode password DEVELOPDBG ON does not work anymore.
I tried the set on feature and OEM setting are still grey out.
I installed a mini bypass and it's still grey out.
So the reason I need the oem setting is because everytime I press one of the buttons from the bottom the display goes off, sometimes it goes crazy and display goes on/off/on, or I loose the screen touch feature.
I think this happen because I clean the screen with a microfiber cloth while it was on.
Any help with this would be greatly appreciated.
Thank you.
