AVH-W4400NEX Bad SD Card
By TheBillTM · Mar 21, 2020in NEX Series💬 15 posts👁️ 8,395 views
Posted Mar 21, 2020 · 00:25 UTC#1
Hi everyone, I am very new here and just pulled my unit from my car because of the dreaded Software Error screen after the splash screen comes up and the screen freaks out. I am OK buying my own SD card and replacing the current one but I was wondering if anyone out there has a good copy of the image on a AVH-W4400NEX and a link with instructions on how to flash it etc. I tried searching here but it seems to just have posts for people asking for images but I couldn't find a repository with them anywhere or links to good ones for this unit.
Thanks in advance,
Bill
Posted May 21, 2020 · 03:51 UTC#2
Thanks in advance,
Bill
I have this issue too. Did you ever get an image?
Posted Sep 07, 2020 · 19:17 UTC#3
Same. The image in the backup thread here just doesn't work. I flashed with Balena etcher and did it manually with 4 different cards with no results. PLEASE, lemme know if anyone has a good image!
Posted Sep 11, 2020 · 04:36 UTC#4
Use that same file from the backup thread page 8.  Download it, unzip it I used WinZip.  Download this program Win32 Disk Imager and use it to transfer the image to an 8GB minimum SD card. You should be good to go I had no issues using this procedure.
Posted Sep 14, 2020 · 02:59 UTC#5
Like I said, I've used the most populat image burner for Mac OS and command line and it immediately just says Software Error every time for 4 different SD cards. Either my head unit is fried or that file is corrupted.
Posted Sep 18, 2020 · 20:05 UTC#6
I don't know anything about Mac systems maybe there is some issue there and this particular file I don't know.  I believe these radio OS files are Linux based, I was able to download, extract and copy the image using my Windows laptop.  If you have access to a Windows based system try it using that as I had no issues so I know the file was not corrupt.
Posted Sep 19, 2020 · 22:45 UTC#7
Have tried 3 different SD cards on mine with different software to write the .img too on my Z810, still get a boot loop. Does anyone know whats good trouble shooting steps after sd card replacement doesnt work?
Posted Sep 26, 2020 · 20:16 UTC#8
Thanks so much for the tips!  I got my W4400NEX running again with a new SD card.  I downloaded the AVIC disk image from the mega.nz link provided in the "Backups and Images" folder on page 8.  I burned it to SD card using win32diskimager.  Helpful tip - you don't have to remove the faceplate connector PCB and ribbon cable on the front of the unit.  You only need to take the 2 screws on the sides off and you can slide the entire face plate drive assembly forward enough to access the SD card.  Use caution when disengaging the plastic face plate from the metal radio chassis.  There are several detents in the metal chassis where bosses on the plastic engage to hold it together.
EDIT - The first SD card that I used had issues.  Boot times were about a minute.  It was a 32GB microSD in a SD adapter.  I ordered some new SanDIsk 80MB/sec 16GB cards and tried one of those.  It totally fixed the issue.  Boot times now are about 10 secs.
The back up cam intermittently coming on seems to be fixed or dramatically improved by cleaning the ribbon cable contacts with acetone and carefully reassembling.
Thanks to those who posted the disk image and excellent instructions!
Cheers,
Ross-O
Edited Sep 28, 2020 by Ross Overstreet
Posted Oct 23, 2020 · 03:59 UTC#9
Cheers,
Ross-O
Hi are you able to send a picture of which options to choose in the win32diskimager program? Thank you.
Posted Oct 26, 2020 · 22:47 UTC#10
My 4400 NEX  has been doing a few odd things...it’s 2 years old.  The first oddity is a tendency to change screens from what I left it last time...it begins playing, then there’s a period of several seconds where there’s no sound, then 80% of the time, it then plays (but the screen has changed)...the other 20% of the time, it will say that it can’t find my phone (iPhoneX, IOS 14.2)....
Sometimes, when it does this, I can go to “Bluetooth Audio”, and get it to play music, but Apple CarPlay isn’t connected....
I have gotten the “Software Error” message once, but that was several weeks ago..it’s not come back.
Is this a potential symptom of a failing SD card, or is there something else going on?
Posted Nov 03, 2020 · 15:20 UTC#11
Thank you everyone for instructions. I had the boot loop as well (NEX-W4400)
I checked for any wiring issues and couldn't find any issue.
Opened the device was able to locate the SD card.
replaced the SD and use the image file from the MEGA file to load it to a faster SD card.Boot loop
large.72e62bfa-3dd4-48cb-a37a-5240daca1d32.jpg.32ab383d7eb46231efa37b2b1cd427de.jpglarge.f33fc5f9-a342-4101-87f7-f6f64ccb7749.jpg.ad7820908f182578e2bdb95e589063fe.jpg
large.6b393825-306e-458d-a8cc-580ceab9281f.jpg.39cb26b78e73b2cfd62c3853558511e1.jpglarge.4e79297d-7fbb-455e-bd98-52209c8609cb.jpg.b4d06387f1204f1a70f0a3a0ddf28252.jpglarge.e37f3438-ccd6-4ac6-9860-fecb8f9e2ab0.jpg.a56c68431508c933f8b6c59da041b677.jpgBoot loop
Edited Nov 03, 2020 by Yakir
Posted Jul 09, 2021 · 23:40 UTC#12
need help.  Did you figure it out?
I will pay someone to create SD disks for me.  I will send you the SD cards.  Help.
Posted Aug 14, 2021 · 05:28 UTC#13
Ummmmm, yeahhhhh, my AVH-W4500NEX SD card die on me, impossible to find the 4500 image…and $200 to do the same thing I am capable of to fix?! I smell a class-action law suit…my unit failed 1.5 years after brand new purchase…seems like a ticking time bomb to me.
Posted Sep 17, 2021 · 04:42 UTC#14
Hi a couple questions to experienced users / owners who have gone through this. I have the AVH W4400NEX and I believe this happened to my unit today.
1. I have only seen the "Software Error" screen a couple times today after trying to start it several times. Usually I just get a scrambled screen and a garbled image of my splash screen. Is that the same issue here?
2. What's the fastest speed SD card the head unit can benefit from? If i'm going to get a a new one should I just get the fastest I could get or will some not read by the head unit?
Thank you all.
Mike
Edited Sep 17, 2021 by mikege — Reason: added
Posted Nov 28, 2023 · 02:29 UTC#15
Just thought id share my experience for others looking to fix their unit. For me my radio was working good. The only annoying issue was my phone wouldn't connect automatically so i had to push a few buttons to get it to function.
So i changed my sd card which fixed the issue however this caused a new problem for me. Android auto suddenly wouldn't work. I have a galaxy s21 with android 13. I was reading in another forum that to fix that you need to download a firmware prior to v1.02 he shared version v1.00 so i downloaded that and put it in the head unit and android auto still didn't work. So I used pioneer site to get the v1.02 upgrade, installed that and now everything works the way its supposed too.
