Issue with D3 bluetooth handsfree and A2DP
By harvester · Oct 28, 2007in Hacks/Mods💬 3 posts👁️ 1,143 views
Posted Oct 28, 2007 · 06:30 UTC#1
Hi,
I am trying to use both D3 bluetooth handsfree and A2DP profiles with my blackjack Smartphone. It looks like both would not work together. Eigther I can get handsfree and a2dp disconnects or the other way around. Has anybody found a way to address that with a Smartphone (I am not sure if it is the smartphone or D3 not accepting both connections to the same device).
Thanks.
Posted Oct 28, 2007 · 13:03 UTC#2
I found that if I initiate pairing from my phone - I get both. When the D3 initiates auto-connect I only get handsfree. Have not worked on this to see if there is a work around.
Posted Oct 28, 2007 · 16:09 UTC#3
The problem I saw with initiating, is that one needs to keep pairing it and the connection to both does not get restored on the next time the AVIC sees the phone. Also it seemed not always to work even when re-pairing.
