No power to unit
By Gfirkser · Apr 13, 2020in Problems/Troubleshooting💬 5 posts👁️ 1,869 views
Posted Apr 13, 2020 · 14:54 UTC#1
Pioneer Navi X930bt
Hey, I recently had a battery replacement and the main fuse had blown in the process. Navi unit is showing no signs of power and I've checked the car electrical fuse box for any broken fuses. None found.
Any troubleshooting I'm completely overlooking here? Does the pioneer Navi have its own internal fuse?
Edited Apr 13, 2020 by Gfirkser
Posted Apr 13, 2020 · 16:14 UTC#2
6 hours ago, Gfirkser said:
Pioneer Navi X930bt
There's a 10A fuse on the back of the unit. If you don't have an installation manual, you should download one. AVIC-X930BT_InstallationManual040511.pdf
What is a "main fuse"?  You need to check check that both power wires have 12VDC (red=switched, yellow=constant). They would be on two separate circuits - so two fuses.  A voltage/multi meter would be useful.
However, I suspect someone screwed-up when replacing the car battery. Maybe + and - wires got switch or shorted. You don't normally blow a fuse when properly replacing a battery. If something did that, it could easily of fried sensitive electronics.
Edited Apr 13, 2020 by RonS
Posted Apr 17, 2020 · 03:30 UTC#3
I feeling dumb af. Couldn't find the fuse in the service manual,can't find out how to remove the unit, no vids online. Anyone?
Posted Apr 17, 2020 · 03:32 UTC#4
Oh the battery was definitely installed backwards! Ha. Ya o have to check if power is making it go the unit and then if the unit is toast. I just want to access the fuse first.
Posted Apr 18, 2020 · 01:09 UTC#5
All double-din units mount the same, but the trim removal for each model vehicle will be different. If it isn't obvious how yours is removed you'll probably need to post question on some forum for your specific make.
