AVH 2550NEX Problem Help
By Eldudderino · May 05, 2020in NEX Series💬 9 posts👁️ 1,008 views
Posted May 05, 2020 · 21:02 UTC#1
So, the last half a dozen start ups the radio will play music. Then once my phone connects it stops and an ! button appears but you cant hit anything. It will then go to a dial screen or will go to what the pictures I attached shows. Ive had this for a few months and this is the first time it has done it.
Posted May 05, 2020 · 22:55 UTC#2
do you have a RR
Posted May 06, 2020 · 16:17 UTC#3
What is a RR?
Posted May 06, 2020 · 18:51 UTC#4
idatalink maestro rr.
that looks like a factory BT.
OEM setups
Posted May 07, 2020 · 14:06 UTC#5
OEM setups
Yes I do. It just started doing this. It completely locks the radio for like 45 seconds.
Posted May 07, 2020 · 16:34 UTC#6
Disconnect the RR and see if it still happen. I know the radio is getting acc. Power from the RR data line. So cut the res wire from the radio and connect to the yellow wire. And unplug the 4 pin idata wire from radio see if it still happens. If it doesnt happen. Then you have a bad RR or firmware on the module. It has something to do with the OEM sources
Posted May 07, 2020 · 19:16 UTC#7
When I installed it the directions were not really that good. Is the factory blue tooth like a silver box? Do I need to remove it? Also my steering wheel controls do not work and from my reading it is because I plugged what looked to be a headphone jack type wire(if i remember right) into the radio from the RR
Posted May 07, 2020 · 20:51 UTC#8
I try tell you what to do to test it. But if i am to hard to understand. Take it to a professional.
Posted May 08, 2020 · 18:30 UTC#9
It seems as though I fixed the issue by resetting the RR. Is there any way to make the volume decrease as vehicle speed decreases?
