Hi. After many hours of screen presses, I figured it out. The Pioneer DMH-W and DMH-WT models have a special hidden menu bypass requirement. No interface bypass is required, but you can leave it connected if it is already installed. Dean and Fernando at Five Star Audio made a video of it on the tubes if you’d rather see it than read it. Here is how to do it:
1. Update the firmware to 1.13
2. Enable the hidden menu bypass by sourcing the radio off (source off, not power off).
3. Press and hold the bottom left corner of the screen for exactly 10 seconds (use a stopwatch as timing is critical).
4. Within 1 second, press and hold the bottom right corner (to the immediate left of bluetooth icon) for 10-12 seconds until a small “set on” icon will appear (in the bottom middle of the screen) confirming the bypass has been activated.
5. If you do not get it the first time, cycle the ignition off and back on and start over.
6. If you need to reverse this process, reset the radio.
