one dumb question
By beaky73 · Oct 31, 2007in General💬 10 posts👁️ 1,268 views
Posted Oct 31, 2007 · 14:27 UTC#1
as i said in another post i will be getting a AVIC-z2 on friday. i am thinking about installing it myself. i am handy. is there any wires i would need to track down. i read somewhere about a spped wire or is it match the wires and go. any help would be great. the unit will be installed in a charger srt8
Posted Oct 31, 2007 · 14:29 UTC#2
what year?
Posted Oct 31, 2007 · 14:31 UTC#3
its a 07
Posted Oct 31, 2007 · 14:32 UTC#4
stand bye 5mins
Posted Oct 31, 2007 · 14:38 UTC#5
vss--dk.green/brown.....@pcm on pass side firewall.........bottom plug pin32
reverse light----white/lt.green.....pass. kick panel......brown 26 pin plug pin 17
everything else you need is in the radio harness
Posted Oct 31, 2007 · 14:41 UTC#6
so i tap into these wires and i should be go to go?
Posted Oct 31, 2007 · 14:55 UTC#7
correct the vss tells the nav how fast your vehicle is going for a true all time possition on the screen
the reverse is only if you add a back up cam
everything else you need will be right in the wire harness for your car
Posted Oct 31, 2007 · 14:57 UTC#8
dide you rock. i did another post about the GPS ateana, does it get intalled behind the radio
Posted Nov 07, 2007 · 00:23 UTC#9
hey guys. i installed my z2 in a 98 expo. but i have the same problom. where is the speed wire? i have searched and searched but i can not find the info anywhere. any help would be great.
Posted Nov 07, 2007 · 00:35 UTC#10
