Acceleration Noise
By heyoceanfloor · Nov 01, 2007in Problems/Troubleshooting💬 4 posts👁️ 971 views
Posted Nov 01, 2007 · 06:04 UTC#1
Hi,
I just installed my AVIC D3 into my 2001 Lexus IS300 yesterday. The install went pretty smooth (I followed a walkthrough that I printed off) but now I've got a problem with the left front door speakers (tweeter and door speaker). I did some searches for the problem and didn't find anything.
When I accelerate, a high pitched noise comes out of only the front left door speakers. As I accelerate faster, the noise gets higher and higher pitched, depending on how far I push the pedal down. The noise doesn't go up in volume when I turn the volume up on the AVIC. I *could* live with the noise, but I'd much rather not! So far I haven't installed an I-pod attachment or anything, it's just bone stock.
Could one of the wires be recieving some interference from the speed sensor wire? I haven't actually opened it up to check yet, I thought I'd get some input on what to look for first.
And a side question.. I'm not recieving radio stations well at all. This is probably because I didn't plug in the antenna wire right? :lol:
Thanks guys, help is appreciated.
Posted Nov 01, 2007 · 13:05 UTC#2
Check your grounds and make sure they're solid. Grounding to the chassis instead of the factory radio ground wire seems to help a lot. If you're using external amplifiers, check the grounds and RCA connections on those as well.
And the radio reception problem, yeah, try hooking up the power antenna wire.
Posted Nov 01, 2007 · 18:58 UTC#3
yes, run a new ground wire directly to the chassis. this helps when integrating with the toyota amplifiers. ive done this on a few lexus cars and it made that noise go away.
Posted Nov 01, 2007 · 21:30 UTC#4
Hey thanks a lot guys, I opened it up today and made much better connections with the ground wires to the chassis and it solved the problem :)
I appreciate the help!
