Help not really any sound
By bigman411 · Nov 01, 2007in Problems/Troubleshooting💬 8 posts👁️ 854 views
Posted Nov 01, 2007 · 21:41 UTC#1
I just tried to hook up my VSS Wire, since it was never hooked up and i made more problems. I thought i hooked it up to the right wire, so i put everything back together and now my z1 does not make any sound when you push the buttons and the volume is so low and my stock subwoofer does not go on anymore. i have a infiniti g35. What did i do? I put everything back together. Is there suppose to be 1 harness not plugged in, in the back. I couldnt find any connection to make it. Oh yeah the speed pulse sensor still does not work.
Posted Nov 01, 2007 · 22:02 UTC#2
put it back the way it was, maybe remote got disconnected?
Posted Nov 01, 2007 · 22:10 UTC#3
I thought I did, what remote? I thought all the plugs are back in behind the unit.
Posted Nov 01, 2007 · 22:22 UTC#4
when i push the z1 and click the buttons it makes no little sound anymore
Posted Nov 01, 2007 · 22:26 UTC#5
how about music and such? if it does play music then you probably just turned off the beep
Posted Nov 01, 2007 · 23:53 UTC#6
the music is really low and its nothing like before, it used to be loud at vol 13 now its so soft and i cant even hear the guidance really. i never touched any of the settings. i did a soft reset and that did nothing. did i not plug a connection in? Also my steering wheel controls are not working, that pac unit that i saw behind headunit.
Posted Nov 01, 2007 · 23:59 UTC#7
get a professional to look at it, also mute isnt on?
Posted Nov 02, 2007 · 00:53 UTC#8
i really think the mute was at -20db, im going to double check tomm, but i still didnt find the vss wire. i thought i tapped into it.
