When I set my feet on the ground and exit the vehicle I go to shut the door or touch any metal and get a shock! The D3 itself is working properly as well as the the Sirius PNR2 unit. Onstar works perfect as well.
Is it not grounded correctly? How would I find the short if there is one.
Here is how I hooked everything up:
I used a GMOS-01 Harness. I used the bypass mod and grounded the parking brake wire coming from the AVIC and the MUTE wire which I moved to the above PIN (Tested the AVIC with no errors and plays DVD's while driving). I grounded them to the harness Ground wire which was connected to the factory harness.
For the PNR2 I connected the power to the GMOS-01 harness Yellow wire. And the ground to the GMOS-01 harness as well.
This is a 2007 Trailblazer. I could really use some help on this one. Thanks!
