"Insert Appropriate Disk"
By bmuhlfeld · Nov 02, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,373 views
Posted Nov 02, 2007 · 12:38 UTC#1
heres what i did........................
took a straw and blew into the head unit to loosen some of the dust that may have got inside. i also cleaned the bottom of the cd....it has a few scratches on it so i think that may be the problem....when this happens if you look into the connections menu it says the satellite cannot be found.......i dunno what to do ...its been working a little better as of late, but this is b.s. man
Posted Nov 02, 2007 · 13:20 UTC#2
Im going to buy a can of air and see if that fixes the problem... I will post back with my results later on today.
Posted Nov 02, 2007 · 21:08 UTC#3
did not work
Posted Nov 09, 2007 · 17:28 UTC#4
replace the disc
Posted Nov 09, 2007 · 17:29 UTC#5
i had that problem. i replaced the disc and it want away!
Posted Nov 09, 2007 · 21:03 UTC#6
hmmmmmmm
