Is this a flex cable issue!
By rbmatl · Nov 02, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,210 views
Posted Nov 02, 2007 · 14:12 UTC#1
Before I go through the hassle of sending in my unit and brain for the flex cable upgrade...do you guys think this isssue is caused by the flex cable upgrade.......Touch Screen does not work on the far left side of the screen. All characters are visible, but when you try and hit a letter it will not do anything or highlight the character to the right of the one that you try to select. Any updated would be appreciated...if this is not related to the flex cable problem..should I go ahead and send in for the flex cable upgrade...thanks
Posted Nov 13, 2007 · 03:28 UTC#2
doubt it's related to the flex cable. Sounds more like the screen needs to be recalibrated.
Posted Nov 13, 2007 · 07:19 UTC#3
With mine, My screen is black, but the LCD light works. Could it be a wire is not connected or something? Cause if it was the flex cable, then that would be the 2nd time in less than 3 months
Posted Nov 13, 2007 · 13:18 UTC#4
Check the connection between the hideaway unit and the display/drive unit......
Posted Nov 20, 2007 · 16:41 UTC#5
I can fix it for you for 150 dollars including return shipping. Check my ebay profile: turbo_tunes
Steve
