VSS Wire
By bigman411 · Nov 02, 2007in General💬 5 posts👁️ 1,272 views
Posted Nov 02, 2007 · 16:12 UTC#1
Where is it on my 04 g35x? I took the center console out and tried to find the wire from my z1. Its the pink wire from z1 on my power cable harness and i tapped into it on a harness that was the top right one that looked white with green stripe. It still didnt do my speed pusle in the unit. Im asking where is the harness from my g35x? I cant find it i guess, there is so many harnesses. Please i dont want to go back and pay the person that was awhile ago. He never conntected it, it seems like. The pink wire was cut short.
Posted Nov 03, 2007 · 14:25 UTC#2
can anyone help? Where is this dam harness when i take everything apart again? Is it the 1 harness that is not connected? Is it the harness that connects to the vents?
Posted Nov 03, 2007 · 21:50 UTC#4
i saw that, how do i know where to locate that area?
Posted Nov 05, 2007 · 05:48 UTC#5
THe White/grren wire will either be part of the harness that goes to the G35 H/U or a seperate wire. Looking at the wiring diagram, it is the only White/Green to the H/U. Don'y get this confused with Green/White.
Based on the diagram it should be bunched with the Green, Red and Yellow for steering controls. If I still had ny G35 I would take a look. If the harnesses are labeled, look for M39.
Michael.
