I recently came across a DMH-1500NEX that was pulled from a car that got into an accident. They said the unit wouldn't power up, but I wanted to roll the dice to see what was wrong. It came with a idatalink RR, which I needed anyways.
Long story short the first thing I did was pull the fuse and to my excitement it was blown. I replaced it and powered up the unit, no logo but it showed a black screen with backlight for about 5 seconds then the reverse camera was triggered. I can tap the screen to show the lines, but none of the buttons work or make any beeping sounds. I have put 12v and ground to the reverse sense wire and still no change. I don't even see the pioneer boot logo or anything.
I attempted to reset the unit by pressing the little pin hole on the right side of the head unit, same behavior. I've booted and held every single button for 15-30 seconds thinking it would bypass and maybe let me either disable to change the setting.
I am at a complete loss on what else to do. I have disassembled the entire head unit down the board to examine for any burns/shorts (since the fuse was blown). I didn't find anything. Do I have a brick? Is there anything I can do?
p.s. One interesting thing I did try was to plug in a android phone to the back and android auto did boot, and showed the restriction prompt saying that I needed to put the car drive. Most likely this was due to the head unit thinking it was reversing.
Posted Sep 04, 2021 · 04:12 UTC#1
