Hi,
Since the car battery was removed a couple of days my F60DAB has started to give problems.
Normal charge but after a few minutes it starts to crash. If you are looking for radio stations, it remains searching without finding anything and the touch screen no longer lets you make any movement.
If you are on a call, the screen is locked and only the buttons work.
The buttons are changed and the + and - now have the radio search function and the audio track change buttons are only used to turn off the screen.
It's quite annoying .. had it happened to someone?
Any solution that I can make? I already did the reset both in software and from the button with a needle.
Thank you!
