Pumori said:
I came across a web page that described how to remove the cover and cut a single wire in the harness of the CD-IB100 (II) to regain full access from the front panel of the iPOD. I can no longer find that web page (did not bookmark it!).
I received a free CD-IB100 (II) with my AVIC-D2 and it is useless with the stock interface and lack of iPOD control. I would be happy to void the warranty by the above method and just control the unit via the iPOD front end.
If anyone knows how to do this modification, please post.
You mean this? Ripped from another post on this forum.
Posted: Wed Aug 09, 2006 3:45 pm Post subject:
Here is another solution I found on Ilounge
For those of you who bought the Pioneer Ipod adapter and want control back of your Ipod when connected to the in car system, here is how you do it with out having to disconnect the Ipod from the dock connector to pick your music.
It will of course invalidate your warranty on the adapter but you will have control. Open up the Ipod adapter box, just two Phillips screws, you should see a connector that has all the wires going to it from the white cables coming into the box from the Ipod. Carefully pull the connector upwards to disconnect it. In the middle there should be a blue wire, lift the little peg that holds the very small socket that the blue wire is connected to and it should now just pull out. Put a bit of electrical tape around it to stop it touching any thing and put the top back on the box. Of course you do this with the power off and pull the power connecter out of the Ipod adapter.
After reconnecting it all, you should now have full control of your Ipod to pick your music. The down side is you loose the auto stop and start when you turn the car ignition on and off.
Back to top
