Has anyone installed an Avic-Z2 on a VW Rabbit?
If so please help me in finding the Speed Information wire and the Accessories wire. Even with the repair manual it's being impossible to find these wires.
Thanks.
Thanks.
I installed a D3 in my 07 GTI, so this should be the same. The speed sensor wire is white/purple and is located behind the speedo gauge pod in the cluster of wires that connects to the pod. As for the accessory wire, there isn't one per se. You will need to tap into an existing 12v line, like the cigarette lighter.
