BTB200 Transfer troubles
By kryngle · Nov 06, 2007in Problems/Troubleshooting💬 13 posts👁️ 1,668 views
Posted Nov 06, 2007 · 03:51 UTC#1
I just installed the BTB200 and Im havin trouble transfering my phone book on my cell to my AVIC D3. When I try to transfer its connects and does the pairing thing and ask's me to connect and I hit OK, it brings me right back to the pairing screen and I keep doin the same thing over and over again but no transfer. I got a LG Shine AKA LG 8700. New phone out. Any suggestions pls?
Posted Nov 10, 2007 · 22:33 UTC#2
Wow 39 views and no help. :?:
Posted Nov 11, 2007 · 16:43 UTC#3
Unfortunately, it's not a very intuitive process and there are differences in how the phones work. With my Motorola v551, I put the D3 in "Phonebook Transfer" mode, then ***from the phone***, push each entry in one at a time. I couldn't get them all to go at once. With a newer phone you should be able to send them all at once. By push, I mean, select the entry on the phone and find how to send that entry to a bluetooth device (Pioneer BT Unit should appear as a choice on your phone).
Posted Nov 11, 2007 · 17:22 UTC#4
how do you get to phonebook transfer mode?
Posted Nov 11, 2007 · 18:08 UTC#5
On the D3, from the BT-Tel screen:
Menu -> Function -> Phonebook Transfer
Posted Nov 11, 2007 · 21:45 UTC#6
I have a Z1 and the Verizon Samsung SCH-u410. It transferred ALL my contacts in one shot. I get no echo. I put speaker set ro passenger side and I crack my window during calls.
Posted Nov 11, 2007 · 22:13 UTC#7
I been messin wit this phone all damn week and I still can't transfer my contacts to my D3 BTB200. I got me the LG 8700 AKA LG Shine. New celly and it jus won't transfer. Pissin me off right now. Any suggestions?
Posted Nov 13, 2007 · 14:24 UTC#8
From what I understand the phone has to support OPP to transfer the phone book. If OPP (Object Push-Pull) is supported, it should be listed as a Bluetooth profile on your phone. I've seen plenty of phones that will pair with the BTB-200, but not transfer phonebook entries.
Posted Nov 13, 2007 · 17:16 UTC#9
Usually when I try and transfer my phonebook I try and send it VIA Bluetooth. Im not ure if thats the correct way. I even tried to transfer it by sendin my name card and nothin. How can I check if my phone supports OPP???
Posted Nov 13, 2007 · 18:26 UTC#10
Look in the manual on your phone under Bluetooth details. Most Bluetooth phones at least support GAP, HFP, and HSP. These are the profiles associated with your average headsets and hands-free applications. There are lots of others, many of which relate to computer functions (Fax, Dial-Up Networking, FTP, etc.). You should be able to find a listing of supported BT profiles in your phone's documentation.
I'm not 100% positive that OPP is what allows phonebook transferring, but I do know the Pioneer CD-BTB-200 utilizes OPP, and the only phones I've seen that I've been able to transfer phonebooks on had OPP capability.
Posted Nov 14, 2007 · 05:27 UTC#11
Well I checked my phone since the manual to my cell is complete useless. I found OP (Object Push) in there. I also saw Fax, Data, Fax/Data options. I tried em all and still nothin. Im playin around wit this thing and Im just lost.
Posted Nov 14, 2007 · 14:27 UTC#12
Anyone who has problems with BT and D3, should try to change the Bluetoothstack on your cell. I tried it and my phone, which shouldn't be compatible with the AVIC-D3, works perfect!
Only difference is, I live in the Netherlands :roll:
http://www.jetwaremobile.com/index.htm
Good luck!
Posted Nov 15, 2007 · 06:55 UTC#13
Well I tried 2 install jetware on my celly USIN my celly to log on the page and its tellin me "The page I requested cannot be displayed"
Whats up wit that???
