2007 camry backup camera question
By er10469 · Nov 07, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,587 views
Posted Nov 07, 2007 · 01:05 UTC#1
Sup guys. I need help.
Can someone please tell me which wire I need to connect the rear gear (violet/white) wire to in a 2007 Camry SE?
I tried connecting it to the positive wire connected to the reverse light bulbs and the screen kept skipping. PLEASE HELP!!! :cry:
Posted Nov 07, 2007 · 03:08 UTC#2
red wire in drivers kick, 17 pin plug, pin #9
Posted Nov 08, 2007 · 22:33 UTC#3
I know this is a stupid question, but what is the drivers kick and can you please be a little more specific on where i can most likely find the 17 pin plug? Thanks a lot. :lol:
Posted Nov 08, 2007 · 22:34 UTC#4
I meant to tell you Misfit, "you're the best"
Posted Nov 08, 2007 · 22:43 UTC#5
drivers kick is the plastic panel to the left of the brake pedal. its a small panel. once you take it off you'll see the plugs
Posted Nov 12, 2007 · 02:00 UTC#6
Thanx a million. I couldn't find the 17 pin plug your were talking about so I just went to the install shop and they ran a wire from the reverse light to the radio.
Turns out that the camera was defective. They tried theirs and it worked fine. Where I got it from thinks it might be a PAL/NTSC issue. They sent me what they said was a NTSC and will be sending me a PAL one. Does this make sense to you? I'll be calling Pioneer to see if they can give some tech support on this. I need to know if the avic d3 uses a PAL or NTSC camera.
Thanks for everything.
