I just installed my review camera, and I have video when I am in reverse but not when I put it in the rear mode, so I would be able to watch a trailer or such. Can anyone help with this.
sounds like your reverse wire is powering your cam, put it to a acc wire instead ![]()
yes, the reverse signal wire is connected to my back light, what is a acc wire, and can I would I connect the signal wire to it?
Accessory wire. what kind of car is it?
2004 Ford Expedition
Black with a
green stripe at the ignition wires, itll have power with the key on only.
do I wire the reverse signal wire to to it?
no wire the camera power to that and the reverse wire to your head unit.
ok, so basically I am taking power from something that is only on when I press the pedal, to power that is on when the ignition is on. But keep the reverse signal wire the way it is?
