DOES ANYONE KNOW HOW TO TRANSFER YOUR CELL PHONE PHONE BOOK TO YOUR AVIC Z2? IM HAVING SERIOUS ISSUES AND NEXTEL NOR PIONEER IS WORTH A DAMM. I AM ABLE TO USE THE PHONE FINE THROUGH WITH THE RADIO, ITS JUST SENDING THE PHONEBOOK.
THNX
THNX
i have nextel blackberry and z2, i cant get phonebook ![]()
good luck i gave up.
Sending Contacts to the AVIC requires support by your phone.
In most cases, contacts are transferred one by one. Again this is a phone firmware thing.
To transfer contacts
Go to the Phone Menu and press the Receive Bus. Cards (I am doing this from memory, so bare with me). The AVIC will disconnect from your phone and go into a waiting mode. On your phone you start the Send Contact process. AFAIK the AVIC will receive as many contacts your phone will send on one shot.
When all is said and done, the AVIC will reconnect to your phone.
I have a Motoroal V3c from Verizon. The Verizon firmware did not allow the transfer of contacts. I changed the firmware to Alltel and there was an extra function to transfer contact - albiet one by one.
So check to ensure your phone is capable of sending contacts. Not all phones support it.
M
I have a blackberry 8300, and it works as you stated with no problems.
I think its timing..
You setup the Z* to wating for the transmission.
Then on your phone you go through the menu's and say send your address book. Your Z* will show that it's connected and state when the file transfer is complete.
I have been trying to Pair my MOTO Q9c and I keep getting a Security error after I enter the Code (1111). Any one else having this problem?
The MOTO Q9c is the same as the MOTO Q9h from Verizon.
Any help would be appreciated.
