Installed BT now I'm getting "excessive vibration"
By jbsengineer · Nov 09, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,138 views
Posted Nov 09, 2007 · 14:03 UTC#1
Installed the bluetooth adapter last night. This did require me to take the D3 out of the dash etc. Now when I checked the connection status I'm getting a "Excessive Vibration" reading. Is this because I tipped the D3 all around when I removed it out of the dash and reinstalled it etc. The 3D calibration did not lose it's settings.
It's mounted the exact same way before I took it out. Nothing has changed. Would resetting the 3D calibration memory fix this?
Thanks.
Posted Nov 09, 2007 · 14:54 UTC#2
moving it wouldnt cause that unless you didnt secure it all the way when you reinstalled it. try sitting still a minute with the info screen on and see if it goes away then start moving and see when it comes back. it usually clears itself up as long as its mounted properly. what kind of car is it?
Posted Nov 09, 2007 · 14:59 UTC#3
2007 Trailblazer. I haven't noticed this at all in the past week or so. Even did a 500 mile trip and nothing.
Posted Nov 09, 2007 · 15:17 UTC#4
You could try resetting the 3d calibration. I get the same issue when I change something with the Z2 in my TB. Usually doesn't take too long to go back to OK.
Posted Nov 09, 2007 · 15:24 UTC#5
I will give it some time. But just in case how can you reset 3D calibration settings?
Posted Nov 09, 2007 · 17:20 UTC#6
i reset the calibration on my unit and blank all the values and the problem went away!
