I have a Z2 made in July. There are 2 harnesses on the back correct? A white one and a black one. Both of these are completely populated. The wire #2 that i am supposed to ground is a RCA wire for a speaker. How do i do this bypass. I know you all think i am crazy and don't know what i am doing but i do, and i promise there are no empty holes. Is there a chance that during July that had a different kind of harness? I have the ebrake wire grounded. I just need this wire #2. HELP!
Z2 made in July, all harness holes populated. Wire Bypass?
Did you even read your other indentical thread? There are three harness on the back of the Z2. Power, connector 1, and connector 2. You are obviously missing one. Get one and stop double posting
I too have the July 07 Manufactured unit but I have 4 empty connectors in the harness. So you must be missing something......
there are 3 connectors with the z2.the wire harness you need to be using for the bypass,will have connections for eg: REAR MONITOR OUTUT,WIRED REMOTE INPUT,REAR VIEW IN,REAR VIEW MONITOR OUTPUT AND GUIDE ON. your installer probably misplaced it for you.if you didnt install any rear cams or monitors no need for it.except for Bypass. when you do get 1 if you still dont plan to have any rear cams or monitors.you can remove those wires from the connector.that way you dont need to try and stuff them in dash.just an idea
