Navigation Accuracy Horrible on 2002 911. VSS cause?
By djstepanich · Nov 09, 2007in General💬 3 posts👁️ 628 views
Posted Nov 09, 2007 · 22:52 UTC#1
I have an AVIC-Z2 installed in my 2002 Prosche 911. The accuracy of the navigation unit is horrible. I installed the GPS under the remote cover on the dash like a few other members had posted.
However, the accuracy is horrible. It is almost always totally off and not sure what is wrong. I realized after install that I didn't hook up thye VSS wire....could this be the cause? If not, other ideas?
Also, anyone familiar with where the VSS wire is on a 2002 911?
Thanks,
Darron
Posted Nov 09, 2007 · 23:15 UTC#2
vss should be gray/pink under driver seat control module.
Posted Nov 10, 2007 · 00:12 UTC#3
And did you put the antenna on something metal?
