Z2 Bypass Disc not working
By PARATROOPER · Nov 10, 2007in Hacks/Mods💬 17 posts👁️ 2,611 views
Posted Nov 10, 2007 · 16:00 UTC#1
I followed your instructions and burned the iso image to a disc. When i place the disc in my radio and hit map, i dont see a feature that says "Upadate" or anything close. Once the disc is in, It does nothing,it just says "Cd rom disk inserted. Is the disc supposed to update automatically? How long does it take to update? If it is updating, how will i know its working? I did the 2 wire bypass already, just trying to figure out the disc now.
thnx
Posted Nov 10, 2007 · 19:38 UTC#2
I burned the disc and loaded it to my z2, I can watch a dvd while Im driving for about 30 min then it shuts off and say " watching from front seat is illegal". Why
Posted Nov 10, 2007 · 19:38 UTC#3
When you put the disc in your computer, are there a bunch of files on it?
Posted Nov 10, 2007 · 19:38 UTC#4
You didn't do the 2-wire bypass.
Posted Nov 10, 2007 · 19:54 UTC#5
the guys who installed the z2 said they did the 2 wire bypass, do you think they didnt? And why does it work for 30 min?
Posted Nov 10, 2007 · 19:56 UTC#6
hyperite, do you know why it says this after about a half hour of driving?
Posted Nov 10, 2007 · 20:15 UTC#7
2-wire bypass is done wrong
Posted Nov 10, 2007 · 20:54 UTC#8
:mrgreen:
Posted Nov 11, 2007 · 22:09 UTC#9
Hypernite, No there are no files on the disk. Only the ISO image. Now that you mention it, was i supposed to put some junk files on the disk as well?
Posted Nov 11, 2007 · 22:52 UTC#10
No, you didn't burn the disc AS AN IMAGE, you just burned the image file. Refer to the stickied thread (40ish pages) if you don't know what i mean.
Posted Nov 12, 2007 · 21:15 UTC#11
Posted Nov 12, 2007 · 21:18 UTC#12
Hypernite, i burned the ISO image correctly and when i put it in the radio, a screen pop ups that states " Cd rom updated already completed" or something to that effect. I know the 2 wire bypass is absoulutely done corrctly. Is there a difference between Method #1 and Method #2 listed on your Stidky? This is getting ridiculous. Thnx for the help
Posted Nov 12, 2007 · 21:20 UTC#13
If the update is already done and you are still unable to watch movies while driving, then you have done the 2-wire bypass wrong. Make sure you moved the wire to correct hole, make sure the pin has seated properly in that hole, and make sure your grounds are solid on that wire and the parking brake wire
Posted Nov 12, 2007 · 21:36 UTC#14
Just for clarification, how do i know if the update is working? When i slap the disc in and hit Map, nothing happens. I just get that prompt about the The update already completed. im positive the wire bypass is done correctly, I grounded both wires. When i start up my system, i get a prompt that states" Improper parking break lead detected" im assuming that is from that green wire i grounded.
Posted Nov 13, 2007 · 04:01 UTC#15
If it says the update is already completed, then the update is "working". If you're getting that improper parking lead, you didn't connect the 2nd wire correctly.
Posted Nov 13, 2007 · 04:52 UTC#16
anybody have the link to burn the z1 to z2 update?
Posted Nov 13, 2007 · 06:21 UTC#17
You can't burn it. You either have to buy it or follow the instructions in the bold stickie at the top of the page
