Speed pulse
By bigman411 · Nov 10, 2007in General💬 6 posts👁️ 926 views
Posted Nov 10, 2007 · 22:25 UTC#1
Ok, i went back to shop and they fixed it, it was never connected. So it moves up and down with a white bar that gets smaller in bars as numbers go up. I thought the numbers are suppose to be the same on the speedo. My numbers only go up to like 8 and I was going about 60 so far. Is that what it suppose to do? What is really this speed pulse sensor?
Posted Nov 11, 2007 · 14:30 UTC#2
the numbers wont match your speedo. as long as it goes up and with your speed its fine
Posted Nov 11, 2007 · 15:19 UTC#3
nothing has really even changed with this VSS wire hooked up. it seems the same
Posted Nov 11, 2007 · 19:46 UTC#4
Give it time to learn. And it will greatly help when you have no satellite reception
Posted Nov 11, 2007 · 22:37 UTC#5
how long do i wait or how will i know its learning better? It changed to 3d learning from simple hybrid.
Posted Nov 12, 2007 · 00:37 UTC#6
Then its working. Stop pulling your hair out over it
