Updating JUST THE MAPS
By DennisOS2 · Nov 11, 2007in Hacks/Mods💬 11 posts👁️ 2,017 views
Posted Nov 11, 2007 · 00:49 UTC#1
I'm OK with the Z1 in general (able to use flash bypass), but only want the new maps. Original Z1 map dB is so incomplete!
Can't only the map partition from the Z2 be copied to the Z1?? I realize this might mean the HDD removal. Is the 'updated' software for the Z2 required for the new maps? Also, I am aware that the new map upgrade from Pioneer does remove the bypass ability.
Is it possible for a work-around specific to just the updated maps like has been done for the entire Z1 ---> Z2 upgrade?
Posted Nov 11, 2007 · 22:49 UTC#2
No can do.
Posted Nov 12, 2007 · 00:41 UTC#3
Why wouldn't you just want to completely upgrade to the Z2 software :?: You can still bypass, its just done differently
Posted Nov 16, 2007 · 03:54 UTC#4
I just did the z1-z2 hdd update...
2 wire trick works on z2.
Posted Nov 16, 2007 · 05:43 UTC#5
and?
Posted Nov 21, 2007 · 02:00 UTC#6
I was just trying not to have to do yet another bypass. The headlight flash works just fine!! Why do a 2 - 4 or 12 wire bypass when a simple flip of a switch works just fine.
So ......... transferring just maps won't work, or more importantly has been tried and most definitely won't work?
Posted Nov 21, 2007 · 02:05 UTC#7
Nope, you're stuck OR you're gonna have to switch to the bypass that doesn't require a simple flip of a switch ever after you do it once
Posted Nov 21, 2007 · 02:32 UTC#8
Man ............. I will limit all future Pioneer purchases. The factory units (including music storage) are so much more convenient. Last Pioneer I purchase.
Posted Nov 21, 2007 · 02:41 UTC#9
Look at the bright side, at least it is easily bypassable. More and more OEM systems won't let you change addresses while in motion, and are impossible or very difficult/expensive to get around
Posted Nov 30, 2007 · 05:30 UTC#10
Agreed, because of this forum and the support, and the instructions on how to bypass, and how to update, I am more likely to purchase another Pioneer unit in the future.
Posted Dec 02, 2007 · 02:30 UTC#11
So, like, its really cool to use lots of add-ons and wires, and bypasses JUST to get the usability that a standard nav system should have ........... right?
You have to be kidding me. Are you brain dead?
I also appreciated this site .............. but NOT because of the inherent wonderfulness of the Z1/2. But because of the resourcefulness of the American public ....... their ingenuity!
Anyone want to disagree?
