The question will they make it for the avic's http://www.pioneer.no/eur/product_detai ... y_id=25-38
Mike
Posted Jul 17, 2006 · 19:36 UTC#1
Ibugsm1 said:
I'll keep my fingers crossed and start saving my pennies, either way if Pioneer doesnt release the X1BT for north america by then I think I'll spring for an Alpine that has it all.
Ibugsm1 said:Alpine IVA-D310 head unit $1400
KCA-100BT Blue tooth accessory $200
NVE-N872A Navigation accessory $1700
=$3300
Pioneer AVIC X1BT will do all of that for $1299 eur or $2435 USD bluetooth, navigation, but it is NOT available in North America.
bzarins said:After reading Pioneer's instructions, it seems like your phone should autoconnect with the unit as long as you register it and turn the autoconnect feature on. They make it sound like you only have to manually connect each time if you don't register the phone. Is this not the case?
Am I safe in assuming that it will not automaticly switch from an audio source to bluetooth when the phone rings? It mentions nothing in the manual about that, although it DOES say that it won't automaticly switch BACK to an audio source after a call is ended. Sooo... any personal experiences?
And a buddy of mine had the Alpine bluetooth adapter with his double din Alpine and ended up taking it out because he thought it was a piece of junk. I recall him mentioning that all around performance was sub-par and call quality wasn't very good either. I believe he's much happier using one of the Parrot add on units.
whtcrxghst said:It typically autoconnects when using the Z1 or 6800DVD or DEHP9800BT and bluetooth. With the D and N series nav systems, they were not designed/recommended for bluetooth use, so they recognize the CDBTB100 as an external unit and may/may not autoconnect. The Parrot will likely work better with a D1, D2, N1, N2, N3 because they aren't supposed to work with the bluetooth adaptor. Next year looks like it will be better, as the D3 has full bluetooth functionality
