AVIC D1 pinout
By mmfvk · Nov 12, 2007in General💬 2 posts👁️ 1,571 views
Posted Nov 12, 2007 · 19:39 UTC#1
Hi all.I am waiting for a D1 to fit on my car SKODA OCTAVIA. The problem is that I have just installed the original bluetooth unit which works as a telephone itself. It is connected to the OEM unit through two wires. The head unit pin shows TEL + and TEL - or AF+ AF- depending on the model year (and mute which is not used because this car is a CAN BUS one so ECU sends order to radio to stop playing sounds). I know the AVIC D1 has a mute in pin, but can any of you tell me what about the other pins? or tell me the pinout?
The bypass will be done using another wire if i am going to use the mute one because if I change the head unit, CAN BUS has nothing to do with the AVIC;and the VSS am sure is in the car own connector ( because it increases volume as going faster), so no problem.
Thanks in advance and I am going to keep on reading/learning
Sorry for my English
