Hey all, this is my first post as I am now the proud owner of a D3 that I got on eBay for $600 (woot). Anywho, I don't know anything about installing car audio equipment. This pretty much forces me to go to the local car audio shop to get ripped off. This guy did a pretty good job over all, but I think he was either being lazy or skipping steps as some of my features aren't working properly. So far, I've been able to keep all of the products in the family and I'll list what I have.
AVIC-D3, GEX-P10XMT, ND-BC2 REAR VIEW CAMERA and the CD-I200 cable.
Problems that I'm having?
Camera works when selected in on the map view screen option, but not when the car is put into reverse.
Can't change the night/daytime display screen for the map. It's looks like it's set for daytime no matter what I change it to.
When I got home I noticed some wires were left over when I checked the boxes. Could someone tell me what these wires do? One is pink and the other is purple with a white stripe.
*sigh* I've been to this place numerous times for then to fix mistakes. If I didn't have to drive 2+ hours away to get the job somewhere else, I would have. It's starting to seem like that wouldn't have been a bad idea.
Here is the problem list.
1. Installed system, but did not connect antenna wire for Navigation, so I had none.
2. Didn't connect "DATA CABLE" (how do you miss this?) so I couldn't use the XMNAV TRAFFIC feature.
3. Both the XM radio and Navigation antenna are inside my car on passenger side dash. The instructions says it's supposed to be on the outside of the car, but they are working find and getting a strong signal. At least that's what the status displays say. So I guess this is no big deal.
Funny story about number 2. When everything was said and done and I found that cable in the box, the guy said to me. "heh, data cable, don't know what that's for, but don't worry about it, I got everything working." I couldn't figure out why it was saying that my Nav Traf feature wasn't working. I got XM going, so it must have something to do with the D3 or something. I looked at my installation book and sure enough found out the problem and went back the next day to have him fix it.
When the camera got hooked up today, we tried to figure out how to get it to come on when it goes into reverse. I remeber the first time everything was hooked up, he told me he did "the bypass". I'm not sure how he did it, but it worked and it wasn't done like it was posted on here. The reason I know this is because I showed him necro's flash tutorial and aparently he had done something different. So that's why we thought the camera wasn't working. So he went in and changed his bypass method to the one that necro posted and still nothing. He told me that in order for the camera to work, that he would have to hook everything up correctly. In other words, he would have to undo the bypass modification.
What I need from you guys is detailed instructions on what needs to be done to fix these two problems. Also, I need to know what to tell him to do with these two wires. If someone has the time and patience to type that up so I can print it out. I would be grateful. Like I said, I have no idea how car audio equipment works nor the tools to do the job. I am at the mercy of this half horse town and I want to get this done right sometime this week.
My car
2000 Oldmobile Intrigue GLS with BOSE system
The original deck has been trashed. The factory amp has been uninstalled and replaced by to other amps, a power cap and 2 12" subs.
Thanks in advance.
