D4 with a DVD changer
By ajallen · Nov 13, 2007in General💬 2 posts👁️ 893 views
Posted Nov 13, 2007 · 20:47 UTC#1
If I add a XDV-P9 to my D4, can I listen to music while the Navigation is running?
I tried to set the route and then take out the nav disk but, it stops working after about 10 minutes and I have to put the disk back in.
I'm looking for a way to listen to a CD and run the nav at the same time.
Thanks.
Posted Nov 13, 2007 · 20:51 UTC#2
Pioneer hasn't made the D4 yet, pal.
But if you're talking about a D3, you can use an ipod, sattellite radio, DVD changer, or CD changer as the audio source while the nav is running.
And just to let you know, when you insert the nav disk and program a route, then remove the disk the route should stay in there permanently until you cancel or overwrite it. You're probably not doin' it right.
