Hi everyone I'm a noob and need some help getting my unit installed, any advice will be appreciated and remembered:
I have a 2007 Ford Escape with a MACH audio system and purchased a floor model N3 as well as a Crutchfield harness that comes with the additional harness for my factory subwoofer
I've heard that it is not necessary to connect the VSS and Reverse wires, is this true?
If I want to connect VSS and Reverse does anyone know where I would find them in my Escape?
As stated I bought a floor model and upon reviewing the contents of the package discovered that there are two black grounds and that they should be connected some how and then fused with a 10A fuse... problem is I do not have the connector or the fuse, what do I need to buy to make this work?
The non fused ground can be connected through the Crutchfield harness and tied into the factory harness I beleive, but where does teh fused ground get connected?
Will I hook up the Blue Antenna Wire, Orange Illumination wire and Yellow/Black Cellular mute wire or are they not necessary?
Lastly, is it possible to put the brain behind the dash and if so how have people done this?
Sorry for asking so many questions especially since I know some of you are real pros, however, I am not and have never installed something as complex as this unit but don't want to pay an installer $300 to put it in for me when I know I can do it with a little help.
Thanks again for any help anyone is able to provide.
