Help! GPS not syncing location correctly.
By Pokémon · Nov 18, 2007in Problems/Troubleshooting💬 8 posts👁️ 946 views
Posted Nov 18, 2007 · 05:37 UTC#1
Just installed my D3 today and went out for sushi earlier tonight so I figured I'd put the GPS to test.
It said my current location was a friends house 5 miles away where I had my navi installed with his help.
Antenna is is on top of the dash board. Wouldn't see why reception would be a problem. DVD disc was in.
Anyone else experience the same problem and have a solution?
TIA.
Posted Nov 18, 2007 · 06:00 UTC#2
Did you mount the antenna on that little metal square? And are you sure it didn't come unplugged by accident?
Posted Nov 18, 2007 · 06:05 UTC#3
Yep, the magnet is there :]
Yep, antenna plug is there.
Posted Nov 18, 2007 · 06:56 UTC#4
In the navi menu, go to hardware info and connection status. How many sats are lit up when you are out in the open?
Posted Nov 18, 2007 · 08:07 UTC#5
3 :?
Just took it apart again to find a solution. Drove it around the block for a little to see if it would update.
Nothing, location still remains the buddy's house. :(
Posted Nov 18, 2007 · 08:44 UTC#6
Looks like the signal bar is at one now. :(
Posted Nov 18, 2007 · 19:01 UTC#7
You should be getting 7-8 sats when out in the open, so try a different antenna location. Or maybe you got a bad antenna or it the wire got damaged during installation
Posted Nov 18, 2007 · 19:05 UTC#8
I was thinking the same thing.
Took it apart for second time last night to slap some tape on there so I could make sure it didn't pop out. Lost a screw in the process :x
Thanks for help bud. Appreciate it!
