ipod touch videos not showing on my d3
By droc · Nov 19, 2007in Problems/Troubleshooting💬 20 posts👁️ 2,965 views
Posted Nov 19, 2007 · 00:07 UTC#1
did search but no useable info heard about new cable coming out but have not seen it anyone no how to fix this problem.
Posted Nov 19, 2007 · 00:29 UTC#2
There is no new cable coming out anytime soon.
Update your IPOD firmware to the most current version. Make sure your TV OUT is set to ON in your ipod's settings. Plug in your ipod to the CDI200. Press video on your d3 in the top right corner of the ipod screen. Press play on the ipod to start playing whatever movie you want to watch. When it starts playing, unplug the ipod from the CDI200; then plug it back in. You should now have video
If you don't, return your ipod for a 5.5 gen one
Posted Nov 19, 2007 · 02:10 UTC#3
it is a music video downloaded off itunes. and it didn't work,what format does the video need to be in to work and in settings on the ipod the video part it says under tv out section widescreen on or off and tv signal ntsc or pal
Posted Nov 19, 2007 · 02:24 UTC#4
Leave those two settings as they are and do what he suggested in the second post.
Posted Dec 12, 2007 · 21:24 UTC#5
Just for the record, I've heard MANY people list those steps, and they do *not* work.
( They do *not* work for an iPod Touch (firmware 1.1.2) and the AVIC-D3 w/ the CDI200 cable )
I disconnected/reconnected/unplugged/restarted/re-wired, everything.
nothing.
I *did* read another rumor about having to use an apple product between the two - maybe a universal dock? Plug the cord into the dock and dock the iPod Touch in it? Anyone able to try this?
Posted Dec 18, 2007 · 18:42 UTC#6
I purchased a new iTouch and it is not compatible for video with the D3. Pioneer was no help on this. So I purchased the apple video cable and patched it into my D3 and it works fine. Pioneer should consider a firmware fix for this problem and train their tech support to not be rude about a real problem!
Posted Dec 18, 2007 · 21:35 UTC#7
Apple added the need for an authentication chip, and Pioneer should fix it??? What you need is an apple firmware fix... or swap it for a classic, because my classic works exactly the way I described
Posted Dec 18, 2007 · 22:04 UTC#8
I can see the argument for returning an ipod classic for an older generation for D3 compatability. But not if it's an ipod touch, as the other ipods don't have a browser function. It's not the same.
Posted Dec 18, 2007 · 22:32 UTC#9
But it is true that Apple and not Pioneer screwed up the compatability with the D3.
Posted Dec 18, 2007 · 22:41 UTC#10
Well yeah, considering the D3 was put out before any of the apple products that have problems interfacing with the D3 were even made. Before the rollout of the ipod classics, ipod touch, and iphone, the D3 was completely compatible with every ipod product on the market. Apple dropped the ball on that one, not pioneer. Apple was just being profit greedy requiring the use of only their adapters with the chips in them for full (or even limited in this case) compatibility with non-apple products.
Posted Dec 19, 2007 · 00:14 UTC#11
All this talk made me realize, if pioneer wants the new versions of the iPod to work with the D4/Z3, that means they will have to license the authentication chip from Apple. That means the consumers are gonna be paying more for the D4/Z3. So, I think we can safely say that we're getting screwed either way.
Posted Dec 19, 2007 · 00:37 UTC#12
Yea fat chance, they are the worst. I like the way they get offended as if you have no right to suggest that there is a problem with their unit. As if your not qualified to find an issue before they do. And that they will tell you they have "never heard of that problem before".
Posted Dec 19, 2007 · 01:29 UTC#13
Apple cables with the chip can be had for what, $50? How much of that are the chip? I would've had no problem paying $50 for the CDI200 cable instead of the $30 that Pioneer charges. I think thats reasonable
Posted Dec 19, 2007 · 02:27 UTC#14
You have no problem paying the extra $20 just so Apple can get a larger cut, even though the cables are achieving the same thing?
Greed will eventually be Apple's downfall. I hope Pioneer strikes back with a better USB interface on the D4, as I will never buy an Apple product.
Posted Dec 20, 2007 · 04:18 UTC#15
I dont think so. It took over 20 years for that kind of shit to almost kill Microsoft. Apple will change their attitude before that happens. I dont think at this point theirs much stopping them from becoming more successful. Apple is here to stay this time in one way or another.
Posted Dec 23, 2007 · 20:09 UTC#16
I am having the same problem. I have seen some people say that their Ipod Classic and D3 are working
D3
Ipod Classic 160GB firmware version 1.0.3
CD-I200
I have TV Out set to on
I have turned shuffle Off
I connect the Ipod and select the video button. The screen that says "use ipod for full control" comes up. Once that comes up I select the video. The Connect TV cable screen comes up on the ipod. I then disconnect and reconnect the Ipod. I have sound but I do not have any video. I have also hit pause and then play again from the D3.
I would like to play with the 1.0.2 software if someone could send me the two files. If you have the 1.0.2 software I would really appreciate it.
Posted Dec 23, 2007 · 20:23 UTC#17
1.0.2 is still in your itunes file. Backup your ipod first and revert back to it. This will cause you to lose all of your files on your ipod so think twice before you do it. I went back to 1.0.2 and it works again with the unplug and plug back in trick.
Posted Dec 23, 2007 · 20:27 UTC#18
If your iPod came with 1.0.2 it is not in your computer. If you previously upgraded to 1.0.2 then it will be in your computer.
Posted Dec 23, 2007 · 20:52 UTC#19
for whatever reason 1.02 is the only working software for video output
Posted Dec 27, 2007 · 02:05 UTC#20
i just got an 80gb ipod classic and have had the same problem as listed up above with only sound. tried all the different methods mentioned but no success. would it be possible to get some type of "extension" from apple to put between the ipod and the ipod cable?
