IDE Flash Drive?
By guruerror · Nov 19, 2007in Hacks/Mods💬 4 posts👁️ 1,095 views
Posted Nov 19, 2007 · 03:54 UTC#1
Has anyone tried imaging an unlocked hard drive to a solid-state flash drive like the Samsung 32GB IDE flash disk?
Given that one of the largest complaints regarding the Z-series is the delayed boot time a solid state hard drive may pep the unit up a bit.
I have access to a couple of these solid-state devices and am tempted to give it a whirl, but thought I'd post to get other's input...in the event that someone else has had the same thought.
Posted Nov 19, 2007 · 05:01 UTC#2
ill test for u if you send me 1 :D
Posted Nov 21, 2007 · 03:37 UTC#3
Theres another thread floating around here in which a member performed tests with several different hard drive makes. It was to try and figure out why the units were rebooting with some upgraded hard drives.
At first the theory was the larger drives had too much current draw. But unless I'm mistaken I believe his test proved the issue was the unit confirms that the installed drive is a toshiba make. It does its first check around the 60 minute mark and then subsequent checks every 15-20 mins, so it would be an expensive test if it failed.
Posted Nov 30, 2007 · 05:32 UTC#4
also keep in mind, Flash drives and mobile hard drives connect differently. So you would need to first find a way to connect the flash drive as the primary drive. Finding a way to change the bios on the Z1/Z2..good luck.
