I am having intermittent issues with the output on my D3. The LF speaker output will drop dramatically at times, often when the unit is jostled. I first thought it was a wiring issue, until I played with the balance and realized that it wasn't grounding, the output level was just lowering in that speaker. I then found that if I turn the volume up past 33, the sound will come back.
It seems like a processing issue with the balance.
Any thoughts or experience on this issue before I contact Pioneer and have to send the unit in for repair?
