NEW AT THIS
By STYLES · Nov 20, 2007in Hacks/Mods💬 11 posts👁️ 1,501 views
Posted Nov 20, 2007 · 02:13 UTC#1
I NEED HELP INSTALLING AVIC-Z2 IN TO A 2006 DODGE CHARGER RT.. IN DETAIL PLS........ SO FAR I CONNECTED ALL THE WIRES TO A FACTORY HARNES, RAN GPS INT. AND REAR POSS. WIRE (THE PURPLE ONE)........ I BUT I GET NOTTHING THE UNIT DONT EVEN LIGHT UP. IM NOT SURE IF ITS THE HARNES, MY WIRING,OR BOTH. ALSO WHATS THE SECOND FACTORY WIRES FOR (THE SMALL SET)...... AND HOW/WHERE DO I CONNECT THE LEAD WIRE(PINK ONE )FOR SPEED DETECTION. I GUESS I NEED HELP FROM STEP ONE........
Posted Nov 20, 2007 · 03:07 UTC#2
lol im guessing you never did car audio before
you need to find ur power wires to make it work
where are you located ???
im sure there is some members here that can help out
Posted Nov 20, 2007 · 03:13 UTC#3
Posted Nov 20, 2007 · 03:32 UTC#4
For starters, check the operation of your caps-lock key, I think it might be faulty.
Posted Nov 20, 2007 · 03:33 UTC#5
lol :D
Posted Nov 20, 2007 · 04:13 UTC#6
I FOUND THE POWER STILL DONT WORK. U THINK A CANBUS INTERFACE WILL HELP OR NEEDED
Posted Nov 20, 2007 · 04:15 UTC#7
you need to fix ur caps button first
Posted Nov 20, 2007 · 05:30 UTC#8
JUST TO LET YOU KNOW THAT THE NEW DODGES DONT HAVE AN IGNITION WIRE IN THE PLUG. YOU HAVE TO MAKE YOU OWN. SINCE YOU HAVE THE WHOLE THING PULLED OUT GO TO THE CIG. LIGHTER AND TAP THE IGN RIGHT THERE TO THE RED ON THE RADIO
Posted Nov 30, 2007 · 05:35 UTC#9
wow, two people who's caps lock is broken..must be a trend.
Posted Nov 30, 2007 · 15:44 UTC#10
Want help?
What people are trying to tell you is that writing everything in capital letters is baaad forum etiquette and is perceived as yelling.
'HOPE THIS HELPS :shock:
Posted Nov 30, 2007 · 16:12 UTC#11
Want help?
You responded to the person who was answering the threadstarter in kind. He doesn't want help, and he was calling (more) attention to the threadstarter's lack of control over the caps.
