did bypass, worked but my ebrake light wont come on anymore
By e46325ci · Nov 20, 2007in Problems/Troubleshooting💬 3 posts👁️ 608 views
Posted Nov 20, 2007 · 16:42 UTC#1
hey guys i did the bypass and it worked but now my red brake light wont come on when the ebrake is engaged.
now the guys who installed it before did tap into my brake wire and i had took that tap off so i could ground it but now my ebrake light wont come on when i engage it, any ideas on why this is happening and how i can fix it guys?
Posted Nov 20, 2007 · 17:33 UTC#2
Either you loosened the parking brake wire from the switch when you were unhooking everything or the wire might have a break in it where the old splice was. Both should be pretty easy fixes.
Posted Nov 20, 2007 · 21:10 UTC#3
ok thanks ill try that later when i get the balls t go outside its freezin! i currently have the battery disconnected hoping it will reset the airbag light that keeps flashing lol
