Z1 and PAC-SWIPS
By rockn_m1 · Nov 20, 2007in Problems/Troubleshooting💬 7 posts👁️ 1,258 views
Posted Nov 20, 2007 · 23:18 UTC#1
I seem to be having a problem with my Z1 and I think the PAC-SWIPS . When I turn the key off it changes the radio station. Can anyone help me with my problem? The unit is installed in a 2003 Tahoe using the Pac-bose wiring harness. Any help in how to fix the problem would be greatly appreciated. Does this even have anything to do with the SWIPS and its power supply?
Posted Nov 21, 2007 · 05:29 UTC#2
I've had all sorts of problems with the Swips...
http://www.avic411.com/forum/viewtopic.php?t=10642
funny thing is, after upgrading to a new/bigger drive an fresh image(same as before), I haven't had a single problem with it...knock on wood..
Posted Nov 28, 2007 · 18:33 UTC#3
I was having all kinds of issues with mine, too (still have a few). What I did find was that if you program it with the engine on and it is a getting a strong, steady current, the programming seems to work much better. If I programmed it with just the ignition on, all kinds of weird things were happening.
Jason
Posted Nov 30, 2007 · 03:49 UTC#4
I heard the same thing about programming it with the engine on. I have SWI-Ps on order to Replace my Swi-X, which is giving me fits.
Posted Dec 07, 2007 · 19:08 UTC#5
ive tried 2 diffrent pacswips and two diffrent z-1s no problems with ether one
Posted Dec 07, 2007 · 19:17 UTC#6
Mine is hosed again...Works sometimes, but more often than not, it doesn't....or more often than that, it does the wrong functions for the buttons I have programmed.
Nothing I've done has helped. Guess I'm just fortunate to have it works when it wants to.
nutzzz: what vehicles are you installing them in?
Posted Dec 07, 2007 · 23:20 UTC#7
2007 mazda 3 hatchback and 2007 cobalt ss the mazda 3 i had to find the swc wire in the car harness not the radio and the cobalt i used the gmahlan11 harness and it has a swc wire in the harness so two diffrent ways wire and two diffrent program modes and they both work fine maybe i just got lucky twice cause i see alot of the pm with troubles
