Had the boot error prior. Ordered an SD card with the 1.02 Firmware installed. Unit boots fine but shows the Disc Eject screen after turning on.
- Am able to manually pull out the faceplate slide. At about 20 degrees it then shows the Faceplate Removal Screen, after 20 degrees down to its flattest point the unit works fine.
- Removed and reinstalled the faceplate at all three screens. No fix. Did a factory reset through the reset button and in setting restore all settings. No fix.
- Seems like an error with the side mechanism. Checked the ribbon cable and reinstalled it. Still no fix.
Is there anything I can do?
Thank you.
