GS300 '02' Reverse Signal Wire Location HELP!
By VirtuousE · Nov 24, 2007in General💬 5 posts👁️ 5,933 views
Posted Nov 24, 2007 · 03:34 UTC#1
Fellas. I need help finding the reverse signal wire location on a 2002 Lexus GS 300. Can someone point me in the right direction? Thanks
'E' :?
Posted Nov 24, 2007 · 18:12 UTC#2
red/black drivers kick 20 pin plug
Posted Nov 24, 2007 · 22:04 UTC#3
Thanks...I could not find that wire on the list!
GS300 1998 -2003
Requires 791 Bypass Module and extra Ignition Key
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE/BLUE (+) IGNITION SWITCH HARNESS
STARTER BLACK (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/WHITE (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLUE/YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE YELLOW (-) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) RED/YELLOW (-) UNDER STEERING COLUMN
PARKING LIGHTS ( + ) GREEN (+) @ BOTTOM RIGHT OF FUSE PANEL
POWER LOCK See NOTE *1 See DIAGRAM 31101_GS300_TOYOTA and LEXUS door lock interface.pdf
POWER UNLOCK See NOTE *1 See DIAGRAM
LOCK MOTOR WIRE GREEN/RED (+) @ DRIVERS DOOR MODULE in DRIVERS DOOR
DOOR TRIGGER GREEN (-) @ PIN 13 IN 25 PIN PLUG AT BODY ECU, See NOTE *2
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
TRUNK RELEASE BLUE (+), Requires Part #775 Relay @ 18 PIN PLUG, IN DRIVERS KICK PANEL
SLIDING POWER DOOR N/A
HORN GREEN/BLACK (-) @ STEERING COLUMN HARNESS
TACH BLACK/YELLOW IN PIN 16 AT 28-PIN PLUG INSIDE ECU BOX, See NOTE *2
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) IN 20-PIN PLUG IN DRIVERS KICK PANEL
FACTORY ALARM DISARM DISARMS with KEYSENSE wire @ IGNITION SWITCH HARNESS
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 THIS VEHICLE'S DOORLOCKS ARE SPECIAL AND WILL REQUIRE AN EXTRA RELAY, PART #775 AND 2 DIODES, TO CONNECT, See DIAGRAM
Posted Dec 02, 2007 · 00:50 UTC#4
where is the that 20 pin plug located? I'm having a hardtime finding it thanks
Posted Dec 05, 2007 · 03:54 UTC#5
Just wanted to let folks know the wire is located in the drivers kick panel...you will have to pull the carpet back to tap into the wire...the plug is on the side of the fuse box...no need to run the wire from the trunk of the car to the front of the car....see pic below:thumbup: this should help folks with future installs the wire is black and red...tested several times with test light...signal is live while in reverse and dead while in any other gear...
